It's the original engine back in it Niall, the one I used to win the Borders , 998 Cooper +40 Graham Russell pistons, Kent 266 cam, Swiftune timing gears and oil pump, balanced, centre main strap, flowed and polished 295 head, 10.4:1 CR, standard valves, twin HS2 carbs, freeflow manifold. Sat on a Morris 1100 box, with Cooper gears, 3.7 diff, centre oil pick up etc. Goes wellcookie1071 wrote:Good to see OB back on four wheels What's the engine n gearbox spec Steve?
The Orangebox Rally Car Rebuild!!
Re: The Orangebox Rally Car Rebuild!!
- rich@minispares.com
Sweet although I thought you'd sold that engine? What are your plans for the car tho? N.SMOKE GREY wrote:It's the original engine back in it Niall, the one I used to win the Borders , 998 Cooper +40 Graham Russell pistons, Kent 266 cam, Swiftune timing gears and oil pump, balanced, centre main strap, flowed and polished 295 head, 10.4:1 CR, standard valves, twin HS2 carbs, freeflow manifold. Sat on a Morris 1100 box, with Cooper gears, 3.7 diff, centre oil pick up etc. Goes wellcookie1071 wrote:Good to see OB back on four wheels What's the engine n gearbox spec Steve?
cookie1071 wrote:Sweet although I thought you'd sold that engine? What are your plans for the car tho? N.SMOKE GREY wrote:It's the original engine back in it Niall, the one I used to win the Borders , 998 Cooper +40 Graham Russell pistons, Kent 266 cam, Swiftune timing gears and oil pump, balanced, centre main strap, flowed and polished 295 head, 10.4:1 CR, standard valves, twin HS2 carbs, freeflow manifold. Sat on a Morris 1100 box, with Cooper gears, 3.7 diff, centre oil pick up etc. Goes wellcookie1071 wrote:Good to see OB back on four wheels What's the engine n gearbox spec Steve?
i did have the engine for sale originally when I planned on building it into a stage car, then realty set in Going to do some Tours in it, Knowldale Car Club do a Mini Miglia Tour. Jeff Smith who navigated in it, did 63 and 64 Mini Miglias in it, and wants to navigate so be rude not to.
I am also in the process of putting as many routes of events the car did onto old 1 inch maps so I wouldn't mind driving those, and me and the missus just having days out in it, oh and try and make Blyton in it at last!!
mk1 wrote:oh and try and make Blyton in it at last!!
NOT BEFORE TIME!
- spoon.450
- coopertim
- Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
Would love to get a photo of OB next to DPU at Blyton next year Steve!
Tim
Tim
coopertim wrote:Would love to get a photo of OB next to DPU at Blyton next year Steve!
Tim
No problem!
Steve just picked an old mini mag up from the garage to read tonight ( while the wife watches another episode of Bake off !!! ) in it is the story how you purchased OB , I love the bit when you began to rub the body down and found where the two cars had been joined and then discovered the passengers Smoke Grey door , brilliant just how stumbling on a bit of rallying history should be .
