Looking forward to all the 'experts' at local shows telling me it can't be a real Cooper S as it hasn't got twin tanks
Mix a small amount of clear coat in with the primer if your leaving it for some time that will seal it, you will probably rub most of it off anyway..Andrew1967 wrote:I’m using an 2k epoxy primer that is waterproof but yes, normally primer is porous so good adviceCostafortune wrote:Don't leave it in primer for months as it absorbs moisture - get a good base coat on. That will settle over the months, find any imperfections and be a very good base to flat off and top coat.
Works really well sometimes....Andrew1967 wrote:No right hand tank Ken ...
Looking forward to all the 'experts' at local shows telling me it can't be a real Cooper S as it hasn't got twin tanks![]()
Yes, its very very similar to HOY, better in some places but worse in others.minimargo wrote:What a great project!
Did you see the similar surf blue mini on Bangers and Cash?
Yes I had the same comment at beaulieu this year . I've also had when I tell them that it's a 970S ... " do you mean a 997 Cooper "Andrew1967 wrote:No right hand tank Ken ...
+1BLT wrote:I can't believe you're painting this already, well done.
