Page 19 of 33
Posted: Fri Oct 02, 2020 7:02 pm
by wantafaster1
Great skills and patience.
Posted: Sat Oct 03, 2020 9:46 am
by roger mcnab
hi d
that is a good result what a pain just when every thing is looking rosy then that happened but better now than driving down the road or at a show and some one shuts the door for you
well fixed
cheers roger
Posted: Fri Oct 09, 2020 1:03 pm
by Dearg1275
An attempt at some colour today where it matters less to see if I have enough warmth in the shed to tackle the shell proper.
It always looks nice when still wet. I have purposely left the unseen areas relatively untouched. Part of the cars history and confirms the originality of the shell etc.
Posted: Sat Oct 10, 2020 7:28 pm
by Dearg1275
Desperate measures. The doors dried and hardened off nicely but the boot today suffered a drop in temperature. Bit nippy outside the workshop. Just got to improvise.
I’m surprised the hot air gun hasn’t burnt out yet. It is doing the trick though. I think things are getting a bit marginal on the weather front.
Posted: Sat Oct 10, 2020 10:06 pm
by spraybeateer
A couple of drops of this in the mixed 2K can be helpful in the cold!
I apologise for adding the photos into your excellent build thread.
so reduced the size to as small as could.
The Count
Posted: Sun Oct 11, 2020 10:04 am
by kevs 1961 mk1
hi i use a calor gas superser heater in cold weather when im spraying works very well , gr8 job your making of the shell ,very talented
Posted: Sun Oct 11, 2020 10:11 am
by Andrew1967
Great work David, looks really good.
I'm a bit stuffed now for painting weather wise, its always crap at the weekends, so might have to sub contract the painting of bits and pieces to Dad when the weather is good in the week and I'm at work !!
Posted: Sun Oct 11, 2020 10:42 am
by Dearg1275
Thanks for you advice and comments. It all helps to keep the motivation levels topped up. Suns out to play today so may be...
Posted: Mon Oct 12, 2020 12:46 pm
by Dearg1275
Nothing ventured nothing gained, so here goes with painting the shell. Section by section to avoid tears.
That’s the workshop shut up until the morning. Fingers crossed.
Posted: Thu Oct 15, 2020 7:12 pm
by Dearg1275
I bought some little helpers to warm the workshop so the fun could continue.
It’s really quite toasty in there now and 2.4 kw was very cheap on the web. Dodging round the off peak electricity might be an idea but going down to the shed at gone midnight to turn things off is not my idea of fun.
Posted: Thu Oct 15, 2020 7:49 pm
by surfblue63
Time switches.
Obviously other suppliers are available
https://www.amazon.co.uk/Guilty-Gadgets ... 08DXRQMYT/
Posted: Fri Oct 16, 2020 8:20 am
by Dearg1275
Good idea. Better than my idea. The radiant heat proved too much and I have ended up with an orange peel finish. Probably too much heat too soon. Time to ignore it for the time being, walk away and do something else.
Any other thoughts on this? Gun, paint and thinners ratio stayed the same (I think).
Posted: Fri Oct 16, 2020 8:39 am
by roger mcnab
hi d you would feel like an eskimo at that time of night
cheers roger
Posted: Fri Oct 16, 2020 8:43 am
by roger mcnab
hi d
i used to get that orange peal effect when i was using 2 pack paint on kitchen doors i used a 7 inch buffer and polished them out they usually came out right do not go to heavy and all should be well
cheers roger
Posted: Fri Oct 16, 2020 11:05 am
by Nick W
you could Give it a week or so and then flat and repaint it..some use this technique when not using a paint booth.
They call it reflow..but it just means that the finish can be better as you don't have to build up layers of paint. You could also add some 2k clear coat to your paint.
Posted: Fri Oct 16, 2020 12:18 pm
by Dearg1275
Nick W wrote: ↑Fri Oct 16, 2020 11:05 am
Thanks Nick. I’m probably being too ambitious. Previously I have tended to let thing go off between coats. I’ll just turn this side to the wall and ignore it for the moment and try again on the other side. Practice, and getting things wrong, makes if not perfect then a bit better.
Posted: Fri Oct 16, 2020 1:33 pm
by Nick W
If there's enough paint on it, you can flat and polish, but solid colour with no clear laquer can go a bit patchy .
For buffing a full car Id get some trazact pads to speed up the process.
Posted: Sat Oct 17, 2020 8:35 pm
by Dearg1275
With the shell spun through 180 degrees time to try again. No heat this time until two hours after spraying. It seems to have worked much better.
Front end to go then I can break out the Old English White.
Posted: Sat Oct 17, 2020 9:39 pm
by kevs 1961 mk1
looks amazing mate wish i had your painting skills its fairly coming along now ,keep up the good work following with intrest
Posted: Mon Oct 19, 2020 1:02 pm
by Costafortune
Looks like the standard Del Monte Longbridge paint finish tbh. Leave it a few weeks and block it with 2000 grit before using 3M Fast Cut Plus and a mop. It looks like there's plenty of paint there anyway.
