Brake Line Leak
Re: Brake Line Leak
We use Dowtys everyday at work.
I'd say that there isn't enough of a flat sealing face on the brake hose for the Dowty to work.
New copper washers will be fine .. always have worked... always will ;)
1071bob
Been thanked: 52 times
Re: Brake Line Leak
Post by 1071bob »
I seem to remember making some special copper washers for the adaptor end, needed to be 11mm I.D and the standard 3/8" I.D for the other side of the Y piece. As Andrew pointed out the sealing area is narrow.
Maddog
Re: Brake Line Leak
Post by Maddog »
You need two different sized copper washers, as 1071 Bob pointed out. I found this out the hard way when I inadvertently fitted two identical larger washers when rebuilding my 850. I could not get the pressure switch and two way union to seal, and had trouble with brake bleeding. When I pulled it apart, the bottom washer had buckled like a belleville washer. As soon as I fitted a correct sized smaller washer my problem was resolved.
rogerotto66s
Re: Brake Line Leak
Post by rogerotto66s »
The two washers are detailed below.
The smaller washer goes below the Union while the larger washer goes above the Union on the banjo nut.
Roger Williams
