'63 Almond Green 8 Port
Richspec
Re: '63 Almond Green 8 Port
Post by Richspec »
whatever minispares sold us years ago, 32mm?
Richspec
Post by Richspec »
forgot to add --- rev counter over reads and speedo is miles out as well, even though its supposed to have the correct drive ratio parts :x
Vegard
Post by Vegard »
Richspec wrote:whatever minispares sold us years ago, 32mm?
Would you use bigger ones if you could?
What did the guys use back in the 60ies on the Ardens?
Richspec
Post by Richspec »
Honestly - I don't know if I need to go bigger yet, the same setup ran well before on another 1380 but using a 296 cam.
I'll get this sorted out first then go from there. :D
Richspec
Post by Richspec »
did 40 miles today, the only time it stopped was when I stopped it to reconnect the temp gauge wire :)
Had a nice blast down the back lines on the way back from Carlisle, off to the Cumbria Classic Show tomorrow. :D
InimiaD
Post by InimiaD »
Good news Rich.
morris-miner
Post by morris-miner »
AOD !!!
I had a Mini Minor AOD476A, wonder if it's still around ??
Richspec
Post by Richspec »
you could search for it on the dvla site?
I got to the show ok on sunday, it was all of five miles each way LOL!
tedmcedd
Post by tedmcedd »
love it! looks fantastic!
im thinking 7 or 8 port next.... hmmm
Richspec
Post by Richspec »
Pendragon Rally Spectator Stage Club display today, had a minor problem..fuel bowl float or something stuck on carb no2 and it was pissing fuel out, we ran it dry, massaged the side of the carb with a persuasion stick and all was well again, I don't think it can of been crap in the fuel - it goes through 3 filters before it gets to the carbs :?:
Also last night i swapped to points - to get my rev counter to work properly (RVI type :oops: ), it still reads high and the car runs worse
InimiaD
Post by InimiaD »
I had a similar problem with H4's years ago with fuel urinating everywhere.
The fault was the Brass float which had decided to spring a leak, filled up with petrol and eventually didn't float.
Luckily my local Leyland garage (remember them.?) had one in stock.
Richspec
Post by Richspec »
its been fine since though, which is odd, I think during winter I'll get a rebuild kit x 4, I know someone with a burlen trade account which is nice :)
JC T ONE
Post by JC T ONE »
Hey RS,
thats some project you have there 8-) reading through your posts took me back to 4 in the morning, some years back, when I started the turbo,
boy was I exited, and all the fumes from varius paint, and oil on all the rebuild parts, its a moment to cherish ;) dont get much better.
keep up the good work.
Jens Christian
Richspec
Post by Richspec »
A very brief update, I've been a busy bunny doing this...
Full detailed build report to follow.
Rich
Long time no see Rich.
I wondered what you had done with that green one, looks good.
Are you thinking of doing Croft this year? It was a good weekend last year and this year should be better.
Stuart
Richspec
Post by Richspec »
Yes, it would be good to get more than a quarter of the way there!
Is there a date set for it yet?
guru_1071
Post by guru_1071 »
your going to have to weld that huuugggeeee gap up between the grill and the airfilter rich!
looks good!
Richspec wrote:Yes, it would be good to get more than a quarter of the way there!
It's on the 6th and 7th of August this year. The Newcastle and Durham region of the MCR are already planning on having a display again, as everyone wants another go round the track.
Details of the event can be found at
http://www.croftmilitary.co.uk/
tomkidd
Post by tomkidd »
Looking good Rich, I bet it sounds nice
Richspec
Post by Richspec »
guru_1071 wrote:your going to have to weld that huuugggeeee gap up between the grill and the airfilter rich!
looks good!
I kept the offcut and I've got some green insulation tape, job sorted :lol:
