I thought it was all good to go but how things can go wrong!!!
before going to Mitp I decided a run out to Croft for the Nostalgia meet would be a good tester, things started well.
but rapidly went downhill
![Smile :)](./images/smilies/icon_e_smile.gif)
this is half an hour or less later.
the rest of the day was spent like this..
with a couple of trips out ending on being towed home
Problems were:
overheating - the standard rad and fan combo just couldn't cope
misfire and cutting out when hot
wouldn't turn over and restart till it had cooled down
not charging properly?? - Amp meter jumping around all over the shop, voltage reading a steady 11V the suddenly going up to 15V, and staying there.
Things we found - wiring from starter button into main loom behind heater - replaced with generic red (like a lot of wires we've found, red or blue!) and running too close to the exhaust and getting very hot and soft when the engine ran for a period of time. So that was checked for continuity (ok) and re-routed.
We also made a heat shield for the starter button assembly as it was a bit close as well.
Dizzy cap loose and getting whacked by the rotor arm as it turned - I've never seen this before, the rotor arm was so tight inside the cap as the arm turned its top face was actually rubbing on the inside of the cap, moving the cap, the carbon centre bit in the cap was fully pushed back inside??
We think the extra thickness of the lumenition kit was pushing the rotor arm too high. By changing to a genuine lucas rotor arm we look to have gained the vital mm or so of space needed..
Last weekend before Mitp I got the new minispares rad on, put a plastic fan on and swapped the alternator just to see if that made any difference. It sort of did...
It now takes time to warm up, and the readings from the ammeter make sense, when you put a load on like lights it responds etc
The volts gauge just behaves the same though.
Bad points - it still broke down repeatedly, misfiring and coasting to a silent stop. However I did do not far off 40 miles and was able to see the pattern emerge, drive for a bit, put your foot down / load the engine = lambda start to go weak followed by cutting out
Drive on the idle jets (ie very slow = no misfires, slightly rich lambda - all good) ish..
We THINK this was the fuel pressure being set too low and the carbs running out of fuel, this weekends testing will prove us right or wrong.
The other thing we found was more bodged wiring behind the heater, the radio wasn't working and when tested all the wiring in that section only showed 1.8 volts but sometimes parts would show 12 etc??
I found this to be that the power was coming off the back of the ignition switch, via two scotchlocks only 1 of which even needed to be there and wasn't making a good contact at all.
At Mitp i bought a new fuel cap to look more period
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
and some special tuning stickers to cover up the holes in the bonnet for now
![Laughing :lol:](./images/smilies/icon_lol.gif)
