Come on V, the whole assembly includes the clutch plate.Vegard wrote:Seriously. I balance the way you do, but then I follow up by fitting the clutch plate. I guess you could make a spacer/washer the thickness of the clutch plate to get the backplate at the correct position compared to the crank mains.
Primary and Drops gears
Re: Primary and Drops gears
Thanks for your input Simon. As far as I am concerned your method is "THE" way to do it. Who else on here can argue with someone who does it for a living.
After all this does seem to be the mini way now a days to pay for extra unneeded work. Simon do you charge hourly or in other words, would you charge the extra for balancing individual components, over balancing a pre assembled clutch & flywheel. Bearing in mind the extra time this involves ?
Smiffy,
Sometimes you just don't know when to let sleeping dogs lie do you!
- Vegard
But Simon cannot do this for you, as he does this incorrectlySmiffy wrote:Honest question mark, as I've a flywheel assembly to get balanced.
Vegard wrote:But Simon cannot do this for you, as he does this incorrectlySmiffy wrote:Honest question mark, as I've a flywheel assembly to get balanced.
- Been thanked: 5 times
We charge a set price for the job , some you win , some you loose on time but they are all done correctly .
Worst one I ever had was a ford side valve that someone had " bladed " with an angle grinder , took hours to get right
Its the same with the rods , you might be lucky and do a set in 30 minutes or they might be miles out and take age,s.
So what do you charge simon and where abouts are you ?
There is only One advantage, to balancing the flywheel/clutch assembly individually. That I can think of and must say I'm surprised one ones mentioned it yet.
We are in south warwickshire between daventry and leamington .
Call 01926 815681 and speak to Rod about price,s
I,m only the monkey not the organ grinder
