Hi, any idea what this entailed.? And any potential problems? Thanksrich@minispares.com wrote:wasn't there a trick of using thinned down s rods on 1000cc cranks to get round the 'bendy rod' problem in old 1000cc miglias???33JOY wrote:lunacy
Inline 1098 engine
- Has thanked: 11 times
Re: Inline 1098 engine
- Pandora
Yes, all the cool folk think along those lines.....L7MAD wrote:Thanks Nick that's a great help. Tom I haven't got a project car for it yet but looking along lines of an A40 or Frogeye or if I can find / afford one a Series 1 Lotus Seven would be the ultimate![]()
Paul.
viewtopic.php?f=6&t=3786
I'm planning an in-line 998, though at this stage if a decent ready built in line engine came up cheap I'd be keen, if only to move the project along a bit (though I'm skint!)
Should get the body back from the moulders within the week
Al
- 33JOY
I think the problem now is finding some small bore pistons with the larger gudgeon pins used with big bore engines/S rods? Miglia pistons were the 'thing' at that time but long since disappeared I guess. I would love to be proved wrong on this.5portsrock wrote:Hi, any idea what this entailed.? And any potential problems? Thanksrich@minispares.com wrote:wasn't there a trick of using thinned down s rods on 1000cc cranks to get round the 'bendy rod' problem in old 1000cc miglias???33JOY wrote:lunacy
Peter
You just sleeve the small end of the rod.33JOY wrote:I think the problem now is finding some small bore pistons with the larger gudgeon pins used with big bore engines/S rods? Miglia pistons were the 'thing' at that time but long since disappeared I guess. I would love to be proved wrong on this.
Peter
- 33JOY
OK, so that's sorted then.
1098 Midget block (2" mains)
1275 crank + 6-bolt flywheel
970 S rods (thinned down and bushed small end) - sorts the 'pistons down the bore' issue
+0.040" 1098 pistons
What can possibly go wrong.....?
Peter
Peter
- Pandora
The good thing about that build is that it uses all the easy to find bits.
Good thing too, as I'm fed up tripping over those superchargers and Alloy heads, so it'll use up some of them too.
Al
Al
If you want a 1098 block....
I have one I keep tripping over in the garage....!
Ed
Ed
- Pandora
Of use to you?
http://www.ebay.co.uk/itm/Classic-Sprit ... 25968bea97
(a bit too pricy for my project!)
Al
Al
