Help on tricky roof repair
Andrew1967
Post by Andrew1967 »
Hi,
The front corner of the roof of my pick up, along with part of the door frame is in a poor state. I have a good repair section, cut years ago from a van to use as a repair.
Question is, is it possible to separate the roller welded roof section from the door frame section without damaging them ?
Alternatively, is it feasible to butt weld the two pieces in together without separating them initially ?
I'll post up a pic of the offending area and the repair piece tomorrow.
Andrew
Andrew1967
Re: Help on tricky roof repair
Here's the pictures of the offending area and the repair piece.
Any tips or ideas on best way to fit this repair piece. ?
Frogeye61
Post by Frogeye61 »
Personally I would cut entire section out, cut repair section to fit and butt weld everything.
IMHO
66S
Post by 66S »
Hi Andrew,
I'd be inclined to butt weld it across the seam too. I think trying to part it could be fraught with disaster somehow.
Has this rust set in because the restoration has taken soo long? :lol:
Callum
Post by Callum »
Had to do this repair on my mk2, I did it in one as suggested and butt welded. Just made a jig for the a pillar so the windscreen and door apatures didn't move.
Andrew1967
Thanks for the answers and I think you have confirmed my thoughts :)
Al, it seems a lifetime since I started this project but I can confirm that the areas repaired with your body parts are still fine :lol:
66S
Post by 66S »
Ahh, so there is some of my DNA in the UK ?? :?
Tupers
Been thanked: 7 times
Post by Tupers »
I'd also advocate butt welding it in.
I did this one on a Hornet a while back although I made the repair section.
pad4
Post by pad4 »
Yep just cut the fkrr out and butt weld a new piece back in
pad (im never doing a full roof again)
Andrew1967
Thanks Callum and Pad, that's what Im going to do.
I'll post up the results in due course :o
69k1100
Post by 69k1100 »
That repair section looks a little suspect?
Andrew1967
69k1100 wrote:That repair section looks a little suspect?
Compared to what I've got on the pick up its superb. :)
Apart from the slight repair required on the gutter, it's sound, having been blasted both sides. ;)
Unfortunately the days of cutting this section out of a scrap Mk1 or 2 are long since gone, so I've got to work with what I saved years ago :(
I actually saved the roof/gutter section for my Mk2 Cooper but the pick up is more needy at the moment :lol:
