Hydro bumpstops
Dr S
Hydro bumpstops
Post by Dr S »
So they should be fitted with the cone bit at the top and the small hole at the bottom.
There is clearly an art to this. Any ideas, boiling water and fairy is nowhere even close..
5portsrock
Has thanked: 5 times
Re: Hydro bumpstops
Post by 5portsrock »
Ive used back to black panel spray. It has a silicon content.
Dr S
Re: Hydro bumpstops
Post by Dr S »
Will they then twist in by hand or is it brackets off the car and vice / press time?
Has thanked: 125 times
Been thanked: 34 times
Re: Hydro bumpstops
You referring to Competition ones?
The Small Hole goes over the steel knob. I use rubber grease to get them on, no issues. I think you'd have a hell of a time trying it dry.
Dr S
Re: Hydro bumpstops
Post by Dr S »
Cheers chaps, grease ordered, one step closer to blyton!
Dr S
Re: Hydro bumpstops
Post by Dr S »
Used silicon spray and popped them straight on. Astonishing stuff. Cheers guys
66S
Re: Hydro bumpstops
Post by 66S »
I ended up adding a nylon plug down the hole to add some more resistance to the front bump stops. The car is almost on the bump stops sitting free.
Regards
