Throttle Pedal
- billycooper
Throttle Pedal
So, i came to fit my throttle pedal on my "60" , It dosn't fit, the bit where the cable goes through is a long way off !, as some of the bits that came with the car where in boxes i'm not sure its the right one, is there different pedals through out the years ?
i'll try to upload a pic tonight
Steve "Murph"
- rich@minispares.com
Re: Throttle Pedal
its probably just got bent if the cable retainer slot wont line up with the hole in the bulkhead.
- billycooper
Re: Throttle Pedal
It does seem to be like 3 inches across, nearer the o/s wheel arch, is there different pedals ?
ive only got a photo with out the pedal in place, ill take a pic tonight, i've missed the pedal stop !
Steve "Murph"
Re: Throttle Pedal
the vertical bit of the pedal that the foot pad welds to does sit very close to the rh inner wing
- billycooper
Re: Throttle Pedal
rich@minispares.com wrote:the vertical bit of the pedal that the foot pad welds to does sit very close to the rh inner wing
Sorry Rich, ill stick a pic on tonight, its the top bit that the throttle cable slides onto is bent and off to the Right, nowhere near the hole for the cable
Steve "Murph"
- billycooper
Re: Throttle Pedal
Pic of pedal
It's as if the bracket needs turning round !, but I can't see how, I'm sure it was fitted to the car when I bought it !
Steve "Murph"
- Been thanked: 59 times
Re: Throttle Pedal
Not sure how you ended up with that gas pedal....it is a LHD pedal!
Here are two pics. of a RHD and a LHD pedal.
Top is a RHD and bottom is LHD
- billycooper
Re: Throttle Pedal
Looks like I need one ! , bl..dy strange that guys I've found pics with it on the car !GraemeC wrote:Might have a spare mate - I can look at the weekend
Cheers Graeme give me a shout if you find one !
Steve "Murph"
Re: Throttle Pedal
fit it on the lh side - problem solved!
it will give your missus something to do at blyton!!
Re: Throttle Pedal
Might be uncomfortable, but one could sit on the handbrake straddling the shifter and use it as is with the left foot.
Actually, there may be some looking for the RHD pedal for a conversion.
- billycooper
Re: Throttle Pedal
now thats a fix !, stick another hole through and bingoGraemeC wrote:Was it fitted by one stud to move be it over to the left?
Steve "Murph"
- billycooper
Re: Throttle Pedal
I think she would prefer the brake pedalrich@minispares.com wrote:fit it on the lh side - problem solved!
it will give your missus something to do at blyton!!![]()
Steve "Murph"
- JohnA
- Location: Up north where men are men and sheep are frightened
- billycooper
Re: Throttle Pedal
JohnA wrote:I've got one Steve, pm me if you want it.
Cheers, ill just make sure I haven't got one in my "stores" first !
Steve "Murph"
