Body differences on a 67
- Vegard
If comparing a 67 Mk1 and a 67 Mk2 What are REALLY the body differences.
I know the rear window and lights obviously, but were any other changes introduced at the same time?
Grille fixation?
Grille fixation?
- Been thanked: 37 times
Re: Body differences on a 67
Here are few items to define the MK11 from the MK1
The fixing screw/nuts that are welded onto the front bulkhead for the binnacle. MK1 had 4....MK11 has 8.
Lip where the front bumper attaches...cut outs for more over rider clearance.
Bonnet doesn't have the round hole under the badge also, a different safety catch design.
Different bonnet latch assembly
Sure there are more.
- Dr.Mabo
- Been thanked: 27 times
There is also a larger cutout for the switchpanel, as the whole crossmember for the dash is a little different.
so long
the Doc
so long
the Doc
- Has thanked: 9 times
would a 67 mk1 still have the further inset bonnet hinges I know the earlier mk1's had them.
- Dr.Mabo
The later Minis have just 6 fixing screw/nuts (not 8) welded onto the front bulkhead.360gts wrote:
And to my experience the change was somewhere in 67 or late 66 but not precicely at the changeover between MK1 and MK2. My current restoration project is an early 67 MK1 with 6 welded fixing nuts.
nick@dunsdale wrote:would a 67 mk1 still have the further inset bonnet hinges I know the earlier mk1's had them.
yes, MK1 and MK2 have the more inwards located bonnet hinges. They moved outwards on MK3 Minis.
so long
the Doc
- Vegard
Thanks guys.
When that is said, I've owned a couple of bonnets With both Mk1/2 and Mk3 hinge mounts. Original?
- Dr.Mabo
No, these are aftermarket/reproduction bonnets.Vegard wrote:Thanks guys.
MK11 has 8 welded nuts....there are two high up under the bulkhead...hard to see...that makes a total of 8!
Now, I was not specific about the MK dates...Yes, you are correct about the 67 having six 6 nuts welded onto the bulkhead.
I have two 67's here..Jan 67 and June 67...both have 6 nuts on the bulkhead. I have July 65 and it has 4!
So, somewhere ...maybe in 66 they added the other two nuts.......must have been a reason.
The middle picture is my 65 S with 4 welded nuts.
Another point...this only applies to MK1 prior to 66.
They had different sun visor mounting holes than a MK11. 66/67 are the same as the MK11
65 was very different.
