cooper s 1968 questions
hi I have a cooper s mk2 68 and I would like to find out the cars original fuel filter and maybe someone has a pic of the rear boot ? as so I know how its mounted. I also have a problem with wipers. when they work they get stuck on the rubber of the windscreen. anyone knows why ?
thank you good day
thank you good day
Morris mini 1275cc 65'
Austin mini cooper s 1275cc 68'
Austin mini Super deluxe 850cc 69'
Re: cooper s 1968 questions
Pop the wipers off with a swift tug and move them round one spline. Can't help with the rest I'm afraid!
thank you much appricaited
- LarryLebel
I doubt there ever was a fuel filter other than the screens in the pump outlet.
- Dr.Mabo
- Been thanked: 48 times
... and the little plastic filter inside the fuel tank.LarryLebel wrote:I doubt there ever was a fuel filter other than the screens in the pump outlet.
so long
the Doc
thanks and where seat belts optional on a cooper s ?
thanks again
thanks again
- Been thanked: 10 times
On a 68 Cooper S seat belts would have been fitted as standard.
1967 New cars in the UK must be fitted with front seat belts by law. Great Britain requires 3-points in front outboard positions.
1968 Great Britain requires retrofit of 3-point belts in front of newer cars.
http://www.google.co.uk/url?sa=t&rct=j& ... 1339,d.ZGU
thanks, and would you know what exact seatbelt was used by any chaNce? as i want to keep the car as original as can be.
best wishes from Malta
BMC fitted either Kangol (alloy buckle) or Britax (plastic buckle) 3 point fixed belts.
Similar to these;
Correct Kangol buckle (wrong webbing)
Correct Britax buckle
The plastic britax was the most common.
Inertia reels like this;
But were uncommon.
Similar to these;
But were uncommon.
http://www.ebay.co.uk/itm/britax-autolo ... 3ceeac88e1
anywhere i can purchase them apart from ebay>?
thank you
thank you
