Minispares C-ARA4442 2 core radiator....
sandman
Post by sandman »
I've bought a Super 2 core rad from Minispares - part no. C-ARA4442...
Althought the description on the website state that this comes with a brass drainplug, this seems to no longer be the case as the two last ones I've seen looks to share the same bottom tank as C-ARA4443 - but without intread of the fan-switch they got what looks like a plastic (or so it looks to me) plug in the bottom RH/front corner as sen on this alloy version:
Now the big question... will these plastic plugs cope with high performance use? (i.e tarmac-racing) or should I replace it... and if so - with what?
Cheers,
Ed_
guru_1071
Re: Minispares C-ARA4442 2 core radiator....
Post by guru_1071 »
ed
they have had the plastic plugs in for a few years, never had any problems with them
sandman
Post by sandman »
So they are okey to run with 21-28 lbs. Rad caps / pressure?
Cheers,
Ed_
guru_1071
Post by guru_1071 »
sandman wrote:So they are okey to run with 21-28 lbs. Rad caps / pressure?
christ, what are you running?
glycol? :lol:
sandman
Post by sandman »
It's cold up here you know :)
Actually I am running water vetter, water and a tad of glycol... but I suspect most others use water and glycol.
Anyway - back to my question; will the plug withstand 21-28 lbs pressure/cap as most (all?) racers use?
Cheers,
Ed_
guru_1071
Post by guru_1071 »
ed
the bungs are used in other applications where they are rated to 100psi.
i suspect the hoses would fail long before the bung did!! 8-)
Fred
Post by Fred »
Ed,
I have used this radiator in several endurance races without any issues.
I took expansion tank off after last season...still no issues.
steady 80 degr with blanking sleeve.
rgds,
Fred
Vegard
Post by Vegard »
I'm running a 24psi cap as well..
