Hi,
im about to have my speedo refurbed and adjusted to suit a 4.1 dif ratio.
However i need the circumferance of a 145 80 r 10 falken tyre to allow the correct settings. Thanks alot for any assistance.
falken sn807 tyre
- Has thanked: 11 times
Re: falken sn807 tyre
145x80x10
It will be about 1084 Wheel Revs Per Mile,
which translates to 1485mm circumference.
There are calculators on the internet that use the rim diameter
and profile to calculate the circumference but BEWARE!
A tyre has a flat at the bottom where it sits on the ground
so most of these values are not valid.
The figure I give here was reverse-engineered from the official
Cooper 'S' speed of 16.08mph/1000rpm on a 3.444 diff.
It should be about as close as you are likely to get...
... or see this!
(Attached)
(Attached)
- woodypup59
- Has thanked: 8 times
- Been thanked: 23 times
The .pdf shows a 145x80x10 tyre with a 1490mm circumference.
This is only 0.3% different to my 1485mm.
Hi Ian,
Im afraid i had finger trouble.
Ment to say thanks alot for posting the info its just what i was after. Regards, Fraser
