Mark One Piano Hinged Rear Quarter Windows
gs.davies
Has thanked: 75 times
Been thanked: 76 times
Post by gs.davies »
Are the frames on these rechromable? If so, how do I get them apart to release the glass?
One of the frames has already come apart, seperating the hinge from teh rest of it, not sure if this is a good or a bad thing?!
Been thanked: 10 times
Re: Mark One Piano Hinged Rear Quarter Windows
Yes.
Not easy. Undo the screws, that will no doubt have rusted solid or even through, that hold the hinge in. These are almost impossible to undo. then carefully part the frame releasing the glass from the rubber seal. Easy as that!
As the Haynes manual used to say, re assembly is a reverse of this procedure. However, it is almost impossible. If your surround is still intact after stripping, something that is moderately unlikely, you can re assemble using a bead of sikkaflex instead of the rubber seal, this makes assembly much easier.
One of the frames has already come apart, separating the hinge from the rest of it, not sure if this is a good or a bad thing?!
It is a very, very bad thing, it means that the lug that holds the screw for the hinge has already rusted through or broken.
It is possible to re assemble the rear quarters sticking the whole thing together with sikkaflex, this will repair a broken window, but is PERMANENT!
gs.davies
Post by gs.davies »
mk1 wrote:It is a very, very bad thing, it means that the lug that holds the screw for the hinge has already rusted through or broken.
Bugger..
gs.davies
Post by gs.davies »
What are the frames made of? Can't be beyond the wit of my friendly metalworker to braze in a new lug or two so that the frame can be screwed together again, can it? (he asks with the naivety of someone only just started shovelling cash in the general direction of a pile of rust..)
The original lugs were rivited, you could make & re rivet replacements. I don't know of anyone who has done this though.
gs.davies
Post by gs.davies »
The guy who is doing my car is a craftsman in the truest sense of the word. Not that these are priority yet, but watch this space.
swifty
Been thanked: 38 times
Post by swifty »
As mark said you can repair these without using the rubber . I used a tube of black windscreen adhesive . Run a thick bead of it in the chrome frames then taped it altogether . I didn't even wipe off any excess . Left overnight the excess came off with a razor blade . Where I run the blade around the edge of the chrome it even looked like it had the rubber seals . I do it this way all the time now .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
LarryLebel
Post by LarryLebel »
I fixed one of the windows. I made a splicing strap from stainless steel sheet, drilled and tapped holes for the screws than pop riveted the strap to the frame. It was a piece of cake.
Andrew1967
Post by Andrew1967 »
LarryLebel wrote:I fixed one of the windows. I made a splicing strap from stainless steel sheet, drilled and tapped holes for the screws than pop riveted the strap to the frame. It was a piece of cake.
Pretty much what we have done with some Mk2 windows. Maybe a little easier as no hinge involved but same principle.
skorstensfejeren
Post by skorstensfejeren »
They can be rebuild, thats no problem. I've have build a couple of sets of Them. Had Them Rechromed and so. They're made of steel, thats why they rust.
I would absolutely use the correct rubber, or Else you cant repair Them again as Mark Said.
They mostly brake at the little bracket, so you can make a new one and have Them fitted with new metal rivets before they are rechomed.
You can find Them on eBay
http://pages.ebay.com/link/?nav=item.vi ... 0440898277
You can one of my sets here.
viewtopic.php?f=6&t=1621&start=220
Last edited by skorstensfejeren on Sun Sep 14, 2014 2:38 pm, edited 1 time in total.
gs.davies
Post by gs.davies »
Thanks for sharing that, nice 1071 too!
Do the frames only come apart at the hinge or do they come apart at any other point? Otherwise, how does the glass get in there?
skorstensfejeren
gs.davies wrote:Thanks for sharing that, nice 1071 too!
Thanks for that.. Glad you like my restoration.
The frame only comes together on theese points. Then Sample Them with 4 small chromed screws. You have to twist the frame carefully over the glass when you put it together again. The most hard part are to get the glass into the rubberseal. That can be quite a job. I sprayed silicone on the glass and seal, and carefully used a rubberhammer to knock the frame correctly together.
