door pillar (a post) and apex panel repair
matic
Post by matic »
hi sirs,
i am now ordering door pillar and apex panel from mmachine. however, i would like to ask you all that is it possible to change these sections (including inner a panel) when the windscreen scuttle and the front wing is still on the car? (my mini has been badly repaired on the door step and a panel. the front wing and fromt panel was changed but there is no rust, including original inner wings (just some minor repairs)
regards
ink
swifty
Been thanked: 12 times
Re: door pillar (a post) and apex panel repair
Post by swifty »
Yes you can fit that panel when the front wing and scuttle are on . If you have the inner A panel from m machine there may be a little bit of trimming to do at the top of it ..... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Dr S
Post by Dr S »
If you are a Facebook user have a look for the mini restoration company. You'll find some pictures of my mk2 with this panel removed for replacement. Should give you a good feel for the job in hand.
Nick
matic
Post by matic »
hi ken
thank you so much. do you have any techniques to weld and align the panel?
hi nick
i am really sorry. i dont have facebook account T_T. can you please give me some photos and advices in here? this can be shared to others as well.
warm regards and really appreciated
ink
swifty
Post by swifty »
This is a picture I took of the same panel welded in . But without the wing on .
Porsche 997 turbo S
I am from Essex
swifty
Post by swifty »
Another
Porsche 997 turbo S
I am from Essex
STG95F
Post by STG95F »
Nice panel to work with goes in very nice . m-machine every time
nick@dunsdale
Has thanked: 9 times
Post by nick@dunsdale »
Nice metal work indeed
swifty
Post by swifty »
Thanks nick , been doing it long enough ... Ken
Porsche 997 turbo S
I am from Essex
matic
Post by matic »
hi ken
thank you so much for posts.
i have seen the post that there needs to weld the inner wing and a post together. can you please advice which position i need to weld it up?
thanks and regards
ink
swifty
Post by swifty »
Ink what I tend to do is fit only the outer panel first by clamping and screwing up . Then bolt the door on and get the door gaps right . When your happy with the door gaps , remove door . Now align up the inner A panel and fit with a few screws to the inner wing only (not the outer a panel) . Now remove outer A panel leaving behind the inner A panel in its already lined up position for welding . Then reposition the outer A panel and door . Then your ready for final welding . .....remember it's easier to dress up / alter the A panel than the door to initially get your door gap . In other words don't try and fit the door in a certain size gap , always make the shell fit the door size ... All the best ...... Ken
Porsche 997 turbo S
I am from Essex
matic
Post by matic »
hi ken
thank you so so much and really appreciate on your post. i will follow your step by step.
by the way, i have noticed on other members' mini that the a post / door pillar needs to be spot weld with inner wing. (see red circle in the photo). this means i have to drill the hole at door pillar and plug weld it to the inner wing after i finish welding inner a panel, door steps and etc, isn't it?
ps. i dont have spot welder, only co2 (mig welder) on hand
regards
ink
swifty
Post by swifty »
Yes if you haven't got a spot welder then plug and weld is fine . Just not as tidy in my opinion . ... Ken
Porsche 997 turbo S
I am from Essex
