Thanks dklawson. I just went back and re-read my badly worded question! Yes, I know how the RVI style Tachos work, I was just wondering if almondgreen's Speedwell Weston Tacho is connected the same way? Sorry for that!dklawson wrote:Spider. Yes, that is an impulse tach. If it is not Smiths, it is similar. Current flowing through the coil also flows through that loop of white wire on the back of the tach and induces a pulse inside the tach which is then measured/processed. Later impulse tachs put the loop of wire completely inside the gauge case. Later impulse tachs can be identified by the presence of a pair of male and female bullet connectors on the back instead of the loop of white wire.
If so, then instead of trying to pick up the current from 12+ve to to the Coil, try the wire between the Coil and the Dissy.
Remember, being an electronic dissy, there is a constant current flow powering the electronics and no doubt it will have an internal filter so the back emf pulses don't mess with the electronics in the dissy. Result - instead of pulsed current (which can be sensed), it would be far smoother and less likely to be sensed.
