Dip switch alternative
mini_surfari
Post by mini_surfari »
Hi chaps,
I want to move the floor mounted dip switch to a switch to go on the dash board... ideally a toggle style.
ive had a browse on svc and holden but cant seem to find anything suitable.
Any ideas or suggestions?
cheers, oli
minimans
Re: Dip switch alternative
Post by minimans »
This is an easy one for you!! E type series 1 left hand drive.
and here's one on flee bay.......... http://www.ebay.co.uk/itm/JAGUAR-E-TYPE ... 3f38ff40ae
ianh1968
Post by ianh1968 »
... or if you want to retain the "press-on, press-off" type
of action, use this switch:
Ref: 68711
http://www.vehicle-wiring-products.eu/V ... /lever.php
with this latching relay:
Ref: 72802
http://www.vehicle-wiring-products.eu/V ... relays.php
Ref: 65811 will do the same as the Jag switch
The switches here are "Lucas" style, as per the early Mini, so would be a good match!
mini_surfari
Thanks Ian and miniman,
The etype switch is the one I was looking at but I tried getting hold of Holden to confirm it with no success, but now you've confirmed it ill go with that!
