Front Wheel bearings
colinandvenie
Post by colinandvenie »
Hey guys, I am renewing the front wheel bearings and wondered if I need to use the inner spacer on tapered roller bearings??
The car is standard '63 850 mini
Colin
dklawson
Re: Front Wheel bearings
Post by dklawson »
Whether you need a spacer depends on the bearings. Some bearing sets were made where you need a spacer between the inner races to hold the two bearings the correct distance apart. Other bearings have extended inner races that can touch each other without needing the spacer.
If you have bought new bearings as a kit, they should come "complete". If they came without a spacer, don't use the spacer from your old bearings with the new ones. If the new bearings include a spacer, use that spacer (and not the old one) with the new bearings as the new spacer will be ground to the correct length for the new bearings.
Doug L.
36inter
Post by 36inter »
Taper roller bearings on a 63 Mini ???
Should they not be ball bearings which the drive hub goes through or is my memory failing me. I used to replace mine on a regular basis as I ran wide spacers, it was the drive hub that always failed.
Pete
Has thanked: 204 times
Been thanked: 77 times
As dklawson has suggested, use all the components that come with the bearing kit, don't reuse any of your old bearing assembly.
Also, as 36inter has said, it would have had ball bering types from the factory, however the taper rollers and ball bearing types are - as a set - dimensionally the same, so they will - as a set - interchange.
Here's a cross section of the drum brake hub that may help;-
If you old bearings have spun in the hub, then you'll also need a new hub too.
colinandvenie
Cheers guys
