suspension help please
captain
Post by captain »
could someone please tell me the thread type and size :?: on a 1980 mini front suspension rubber cone a friend needs to strip a mini moke subframe and I only have the early unf size thanks in advance
carbon
Re: suspension help please
Post by carbon »
Suspension cones for the post-76 'single bolt' subframe should all have the metric 14mm thread.
I think this is the 1.25mm pitch thread, someone else may be able to confirm.
ianh1968
Post by ianh1968 »
M14 is correct, but I just put a thread gauge on my puller tool
and it looks like M14x2mm.
M14x2mm is the "Standard" M14 (Coarse) thread, so a
piece of all-thread bar and some M14 nuts from a fixings
supplier would probably be usable as a puller tool.
M14x1.25 is Sparkplug!
Another confirmation suggested...
carbon
Post by carbon »
Ian - you're right, it is 14mm x 2mm pitch thread, my mistake
IAIN
Post by IAIN »
http://sykes-pickavant.com/products/sus ... n/66033000
If you have a sykes tool you can buy the metric threaded end on its own. See the spare parts numbers above.
captain
Post by captain »
thanks for all your help ,job sorted :D
