primary gear running clearances
Speedwell Sprint
Post by Speedwell Sprint »
What's the running clearance of the primary gear on the crankshaft. Mine is .005 and .006, I think this is too much?
dgear1984
Re: primary gear running clearances
Post by dgear1984 »
Speedwell Sprint wrote:What's the running clearance of the primary gear on the crankshaft. Mine is .005 and .006, I think this is too much?
My haynes says .0035 - .0065
Speedwell Sprint
Looking for the clearance on the crankshaft tail. Primary inner diameter to tail outer running clearance. Dont think
Its specified in the book thanks
carbon
Post by carbon »
Section A.18 in BL workshop manual AKD4935 states the following 'the primary gear bushes must be line-reamed to 1.3775 to 1.3780 inches (lubricated bushes only)'.
I don't have the diameter for the crank tail, but this should give an idea of the specified running clearance.
Has thanked: 199 times
Been thanked: 75 times
There maybe some helpful info in this thread
viewtopic.php?f=3&t=7645
Speedwell Sprint
Spider wrote:There maybe some helpful info in this thread
Perfect!! Thanks
