Dunlop d1
chaucer
Dunlop d1
Post by chaucer »
Got bit of an issue put my car on its wheels today was hoping to use a set of Dunlop
That I have acquired but they stick out too far I wasn't hoping to use wheel arches
I am using genuine mini fins and have fitted hi Los let me know your thoughts as you can see it just doesn't. Look right
dazibee
Re: Dunlop d1
Post by dazibee »
Need to know what size and offset your wheels are
pad4
Re: Dunlop d1
Post by pad4 »
Minifins as in drum brakes on the front ?
pad
chaucer
Re: Dunlop d1
Post by chaucer »
Mini fins on the rear wheel size is 10" unsure of the offset will it be stamped on the rim ?
Pete
Has thanked: 57 times
Been thanked: 147 times
Re: Dunlop d1
Post by Pete »
If they're original D1's you won't need to know the offset because they only made one type and they're barely passable with 145 tyres on and S brakes. That's why you see very few on S's and so many on Minis with small brakes. If they're repros I haven't a clue.
Hope this helps.
In the shed
Re: Dunlop d1
Post by In the shed »
Yep, they stick out too far. They are barely passable on drums, but whack a set of S disks on and they are out too far.
If you want 165s to fit, track down a set of compomotive multispokes.
Pete
Re: Dunlop d1
Post by Pete »
Despite my previous post I will say I've had two S's with them on though, not bad on the front if you can get a bit of negative but certainly not ideal as this shows...
chaucer
Re: Dunlop d1
Post by chaucer »
Thanks for the reply guys have decided to put steels on I already a set car is running on a discs can adjust the camber but still wouldn't be right to the eye it's a shame I love the d1,so will posting them for sale soon on the forum is a shame as I have a complete set :(
wantafaster1
Has thanked: 18 times
Been thanked: 11 times
Re: Dunlop d1
Post by wantafaster1 »
Chaucer are they 165 tyres in your picture?
chaucer
Re: Dunlop d1
Post by chaucer »
Yea they are 165 even with 145 they will stick out didn't really want that look
CooperTune
Been thanked: 9 times
Re: Dunlop d1
Post by CooperTune »
I have a set of Org. D1s and I have run them though two sets of 145s without flares. Cooper S fronts and super mini fins rear. Let me know what you get for yours as I want to move mine along also. Going for 4.5 S offset minilites with 165s. New power is more than the 145s can stand. Steve (CTR)
chaucer
Re: Dunlop d1
Post by chaucer »
Will keep you posted thanks for the info
