Mark, you are quite correct in theory, and I was wondering who would comment on that one.
They should be around the length that you are suggesting. However, even though the build is a new block, head , cam, cam followers, etc, the Windsor roller rockers require to be shimmed to the correct level to enable the rocker roller to “roll” over the correct part of the valve tip as the valve compresses (which although they are new valves, were slightly longer by a few thou than specification). The combination of all this dictates the pushrod length.
I have carefully measured numerously valve lift/spring crush, pushrod in out shake it all about and mocked up (welded) a makeshift pushrod eventually to the correct length..hopefully…and all seems to operate correctly at the dimension that I have arrived at?
Hopefully.
