I bought this camshaft recently, does anyone has more information on it?
Is this cam worth something?
It is an AEG-643. I have been told it was used in old formula juniors.
Can this be used with any mechanical fuel pump?
grtz!
a guy in Harrogate used to have a dry sumped 'big' arden race car, I think the dry sumping helped mainly to control the oil temperature and the foaming as there was so much more oil in circulation and so little actually in the gearbox.Vegard wrote:I've never understood how dry sump could work on a Mini. Could someone please explain?
But surely, on a Mini you'll need some oil in the dump for the gears??rich@minispares.com wrote:a guy in Harrogate used to have a dry sumped 'big' arden race car, I think the dry sumping helped mainly to control the oil temperature and the foaming as there was so much more oil in circulation and so little actually in the gearbox.Vegard wrote:I've never understood how dry sump could work on a Mini. Could someone please explain?
he certainly had the results and the performance to back the value of the system up, but I suspect modern oils are probably the better option now
