Hi all
I am about to buy an exhaust system for VFF. The engine is 1293 with the standard manifold not 3 into 1 and i want a centre exit exhaust as per EJB. Im going for a single box system so what parts and accessories will i need as the car still has the original floor start set up.
Centre exit exhaust
Re: Centre exit exhaust
This doesn't answer your question directly, but it's a data-poi t worth sharing, I believe. I just fitted a single-box RC-40 (left side exit) to my '61 with a 1275, a Maniflow Cooper Freeflow manifold, rod-change shifter, and a floor-mounted starter button, and it all fit just fine.
I had people tell me that the manifold was a 'small bore' manifold, and would be too short for the 1275. I had people tell me there wasn't enough room for the shifter, exhaust, and button.
Maybe I'm just exceptionally lucky....
- In the shed
Push button starts are better left rerouted IMO.
There (I forget exactly what it looks like now) are live elements which a larger pipe can short out. One day mine moved and shorted out and boiled the battery. It was quite frightening.
I think it is good form to earth a solenoid via the switch, rather than run the gauntlet. It really is tight in there. Be careful.
been there done thatIn the shed wrote:Push button starts are better left rerouted IMO.
i"d just finished chopping up the maniflow Y piece that came with my 8 port manifold so it actually pointed down the tunnel
had to do more choppage and re welding to get it by without touching!
Caution
may contain 8 Ports, Xe's and VTec's, I don't do standard!
Caution
- coopertim
- Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
- Has thanked: 27 times
many thanks for your comments guys! It seems that the little floor start causes all sorts of issues! I think it will have to be the works style upswept exhaust....it looks fantastic! I will go for a 3 into 1 down pipe and modify as required.
- coopertim
having said that.....has anyone on here fitted one, and do they sound nice?
cheers. tim
cheers. tim
