wheel studs
slowboy
wheel studs
Post by slowboy »
please can anyone advise, what is a good coarse thread stud upgrade that uses nuts with the correct angle on the taper, is anything easily available ? thankyou
InimiaD
Re: wheel studs
Post by InimiaD »
Swiftune do some really nice replacement studs. Not cheap, but they are the dogs.
rich@minispares.com
Re: wheel studs
Post by rich@minispares.com »
slowboy wrote:please can anyone advise, what is a good coarse thread stud upgrade that uses nuts with the correct angle on the taper, is anything easily available ? thankyou
ive never seen mini studs available with anything but the normal 3/8th unf thread
I suppose you could look at using later rover metro 100 as they used a coarser metric thread
'long beard boss'
Vegard
Re: wheel studs
Post by Vegard »
I've been thinking several times about redrilling the hubs, fitting 12mm bolts. It would be great as the 3/8UNF ones are a bit weak. I now use a torque wrench EVERY time when fitting nuts, never a problem anymore.
slowboy
Re: wheel studs
Post by slowboy »
thanks guys, am wanting coarse thread for longevity and quicker on and off , will see what swifty has
GraemeC
Re: wheel studs
Post by GraemeC »
Quicker on/off - just treat yourself to a decent cordless impact driver
sandman
Re: wheel studs
Post by sandman »
Be adviced that's Swiftys studs are only suitable for open-end nuts as used with Rosepetals or as the stock nut from waay back...
Cheers,
Ed_
Vegard
Re: wheel studs
Post by Vegard »
sandman wrote:Be adviced that's Swiftys studs are only suitable for open-end nuts as used with Rosepetals or as the stock nut from waay back...
I'd say that depends hugely on which wheels you are using. Genuine Minilites are no problem as the face of the wheel is very thick, but you've got a point.
