Brake issue
ductape009
Brake issue
Post by ductape009 »
At the moment I'm working on my pile of a 65'. I'm having a problem getting the L/R brake to actually work. I've gone through and bleed the system and set the adjusting screw all the way in. Yet the drum still turns. I checked the obvious and still no no luck, the shoes are like new, drum is fine and the adjusting screw is working. Am I missing anything? Come to think of it are the adjuster block deals the same for all generations of minis? Thanks for any ideas.
-Andy
ductape009
Re: Brake issue
It just occurred to me the wheel cylinder could be bad.
InimiaD
Re: Brake issue
Post by InimiaD »
The pistons in the wheel cylinder will seize up if they have not been used even after a short lay up.
I'm contemplating using Silicone Brake fluid which is supposed to cure that problem.
ductape009
Re: Brake issue
And guess what was bad....
