1098 MIDGET CRANK / FLYWHEEL HELP
- Been thanked: 6 times
Does anyone know what the following inline crank is for
1098 stroke
1.750" mains
1.625" be
6 BOLT AND DOWEL FLYWHEEL FITTING ???
1098 stroke
1.750" mains
1.625" be
- Simon776
Re: 1098 MIDGET CRANK / FLYWHEEL HELP
Isn't that just from an early 1098 Sprite/Midget before they changed to 2" mains?
- Been thanked: 9 times
Would the 1098 Sprite engine not have a 4 bolt flywheel fixing?
Thats what I can,t work out , thought the early 1098 midgets were 4 bolt
Long time since I had one but that was my belief. In fact I'm not altogether sure that the later 2inch main had a 6 bolt flywheel either? I know I have a 4 bolt flywheel here which looks the same as a 1098 Minor one but has a larger centre hole and the 4 bolt holes are further apart......I assumed, possibly wrongly, that it was off a 2inch main engine
- Lord Croker
It certainly is a mystery, 948 & 1098 Midget engines had a 4-bolt fixing, 1275's had 6 bolts & 2 offset dowels. However, I have just been searching around & find that there was a 1098 Midget / Sprite crankshaft with 2" mains, so I wonder if there were any smaller ones floating around with 'prototype' 1275 flywheel fixing. I guess the only way to prove or disprove that is to see if the 1275 flywheel will fit.
There is a 2" main 1098 crank on ebay at the moment and that has 4 bolt fitting .
Checked the stroke on the one I have and it,s 3.300" .
A 1275 6 bolt midget flywheel will fit.
It,s brand new , still in protective oil / wax
Put it on ebay with pictures
Open to offers , no use to me .
Somebody emailed to say it was out of a 1098 marina , ital ??
121132086476
Could it be south african ?
121132086476
251 ENG wrote:Looks like it may be out of a 1098cc MARINA VAN![]()
that would make sense, as a commercial would have a heavy duty clutch in it maybe?
mind you, it would need it with a powerhouse 1098 engine in it!!!
