Hi...
Can anyone tell in the Retainers for the floor board original was putted on with rivets from the back ( inside the retainer ),
or the other way. ( from inside the car ) ?. Seems like you need at quite small and long head on the rivetgun?
René
Rivets
- Been thanked: 6 times
Re: Rivets
Hej René
I just made this Pics for you. In my opinion the Rivets were putted from the inside of the Car to the Floor.
One is on the Passenger side on the Front the other is a Pic from the Drivers Side rear.
The Car is a November 62 Austin Cooper and the Retainers were never removed.
Maybe you have to machine/ modify a Head for the Rivetgun...
Good Luck and let me know how you are doing it.
Regards
Fabian
Regards
Fabian
Re: Rivets
Hi guys,
I managed to replace them with a regular pop rivet gun but I fitted a spacer (sleeve) over the stem of the rivet before I fed it into the gun. I also found I had to choose a rivet that seemed a bit long but as it collapsed, it was drawn in.
Regards
Regards
Re: Rivets
I think René is referring to the boot board brackets.
And to answer that question, I believe the 2 'rectangular' pieces that go in the rear seat panel are done from inside the car (seat removed of course). The other 3 near the bumper are done from outside the car, bootlid removed. At least I've done mine this way as my gun also has a fat head.
Re: Rivets
Hi Ricardo,
You might be correct. If so, my '66S had them installed from the boot side of the bulkhead.
Regards
Regards
Re: Rivets
ricardo wrote:I think René is referring to the boot board brackets.
Hi Ricardo...
Thats are the pieces i ment... And also did it that way. Got a picture from an original one where the Retainers haven´t been removed. They where also fitted from inside the car.
To the other guys. Thanks for your help
Cheers René
Re: Rivets
Thanks for your help Fabian... very kind of youFanfaniracing wrote:Hej René
Regards
Fabian
Re: Rivets
Hi guys.
Sorry for my poor english... I didn't read it right the first time.
As ricardo said, my Brackets on in the boot were also fixed with the Rivets that way.
Regards
Fabian
Regards
Fabian
