External hinge doors on a later shell?
Brynmor
Post by Brynmor »
Just wondering is the above possible to do? Reason I ask is someone I was talking to yesterday has a Mini with Mk1/2 doors but everything else is later??? (I may add I've not actually seen it yet but he insists it is thus)
JC T ONE
Re: External hinge doors on a later shell?
Post by JC T ONE »
I have fitted external hinges on my race Min (MK III) but the doors are completely cut out on the inside, and have plastic windows
Has thanked: 4 times
Been thanked: 17 times
Post by Tim »
Is it a UK body? Australian Minis had external hinges until the end of production in 1978.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
chichestermini
Post by chichestermini »
http://www.ebay.co.uk/itm/Austin-Mini-w ... 2a28e55812
This is a later mini with what appears to be some form of modified hinges attached to a non-mk1 door, you might be able to send a message asking for details?
She's not exactly all to my taste, but doesn't look like a bad mini at all from the pictures at a reasonable price.
Hope this helps ;)
Here's a hinge kit from a UK based firm. A bit pricey.
http://the-arc-angels.co.uk/shop/index. ... uct_id=287
And here's the Japanese ones which have benn around for a while
https://www.mini-delta.co.jp/shop_class ... l1404.html
Brynmor
Post by Brynmor »
Hmmm we're sort of getting there, spoke to him again last night and he tells me it's the full door (ie sliding windows/door bins/external hinges?)...but other than that it's all 1980's Mini...I've asked for pictures but they've not yet turned up...cheers all so far
This is BY FAR the hardest way to do this. Most of this type of conversion involves putting ext hinges on a late pattern door. To make a MK1 door fit a late pattern shell IS VERY DIFFICULT! The shape is completely different.
If I was you I would hang fire to see some decent pictures, & if you don't mind I would really like to see them posted here.
Pete
Has thanked: 39 times
Been thanked: 105 times
Post by Pete »
Sounds like an old 'un with modern trim Bryn, if it's not I wouldn't touch it with a proverbial.
Brynmor
Post by Brynmor »
Oh it's not for sale chaps...it's languishing in a garage in Mid Wales!!
814CWE
Post by 814CWE »
know sombody who dropped the roof line on a later car to take mk1 doors by welding the top door frame off an old door into the top of the door aperture..fitting mk1" a" pillars and skins and grafting 2 back wing sections in off a scrapped mk1
the results actually were very good,,,though im sure he should put his welding and filler skills to better use... :lol:
Lilihip
Post by Lilihip »
I will be doing a full mk1 conversion on an mk3 car. i will post pictures of the doors once they are done
Austin Cooper
Post by Austin Cooper »
I have done this, albeit with lightweight mk3 doors. To fit mk1/2 would require a huge amount of work and it's just never going to be worth the effort. I used a mk1 inner A-panel and mk3 outer, the doors are double skinned where the hinges attach. All the unnecessary holes on the A-post have been welded up. I don't have any pictures of the end result, so here are the best I have.
