Took it appart expecting to find evidences of a short circuit, but didn't find anything. No black marks or signs of unusual wear/something wrong.
After a couple of careful re-assemblies having always the same result, I bought self welding tape and isolated everything POSITIVE that could be touching the case/body (earth), top cover and big clamp. A few assemblies later I was still having the same results. I checked and rechecked with the help of a lamp (my multimeter died last week) every part on the case and:
- Body/case: No current is passing to the body or field plates (100% sure!). Current only flows on the thick winding 'wires', POSITIVE brushes and respective holders properly isolated from the top cover.
- Armature: No current is passing from the commutator to the shaft/body. All commutator 'lines' are connected.
But:
- If I connect the battery positive terminal to the starter threaded pin and earth one end of the lamp, it turns on if I use the other end on the case.
After a few careful checks, I noticed that this only happens when the positive brushes touch the commutator (the armature is not fouling anywhere, I'm sure of that, and the threaded pin has the plastic isolator). I believe that my lamp should NOT be on and this is what's causing my short circuit. Can anyone confirm my thoughts?
Oh, and I tested another worn starter I have and the results are exactly the same, even after a few parts swapped to track down (inconclusively) the problem. I don't think I'm doing it wrong, but I must be missing something. If you put 12V on the starter and earth the case, it should work, right? Mines are just sparks!
Can anyone help? I'm running out of ideas and a little lost.
