Flywheel Bolt Thread: UN or Whitworth?
ianh1968
Post by ianh1968 »
Both ends of an 'A' Series engine crank have the same thread.
It is 5/8" by 16 TPI (Threads Per Inch).
IT IS NOT 5/8" UNF (18 TPI) !!!
This is fairly well known, but what is the thread type supposed to be?
Is it 55 degree, round top/bottom "Whitworth" (British),
or 60 degree, flat top/bottom "Unified" (American)? :?
I suspect that the thread is 5/8" by 16 UN as most of the other threads
on the engine are either UNF or UNC.
Some of the "fluid" ports use "pipe threads", others don't:
The oil pressure outlet thread is 1/8" NPS (Straight), for an 1/8" NPT (Taper) adapter. (American)
On pre 1990 engines, the oil filter head is 1/4" NPT for the feed pipe. (American)
On pre 1990 engines, the oil pipe banjo bolt is 5/8" UNF. (American)
After 1990, both ends of the oil pipe changed to 11/16" UNF. (American)
The rear block water drain bung is 1/4" BSPP. (Parallel/Straight). (British)
The oil pressure relief valve is 1/2" BSPP. (Parallel/Straight). (British)
Are there any "Thread-Nerds" amongst us?
Please post corrections if any of these are wrong and I'll amend the thread. :roll: (Sorry!)
Smiffy
Re: Flywheel Bolt Thread: UN or Whitworth?
Post by Smiffy »
It's WF, 'Whitworth Form' tells you in the BMC manuals.
ianh1968
Post by ianh1968 »
Thanks, Smiffy!
What's left of my Dad's old "Austin Seven Workshop Manual" is archived out in the loft, I never thought to check in there...
I must confess that several years ago I did acquire a 5/8"x16UN tap and have been using this to "clean out the threads"
of various cranks. Maybe the threads in the crank are machined a bit sloppy as using the "wrong" tap has always been
successful...
:oops:
Smiffy
Post by Smiffy »
ianh1968 wrote:I must confess that several years ago I did acquire a 5/8"x16UN tap and have been using this to "clean out the threads"
successful...
You wouldn't be the first, even 'Mini experts' where under the same impression until a few years ago...........
Has thanked: 125 times
Been thanked: 34 times
ianh1968 wrote: Are there any "Thread-Nerds" amongst us?
Yes I have to confess....
The Crankshaft Threads ARE actually British Small Arms Thread ;)
http://www.mokesinc.org/index.php/topic,9692.0.html
Has thanked: 4 times
Been thanked: 17 times
Post by Tim »
It wouldn't be that small an arm if it has to use those chunky big threads. :lol:
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Tim wrote:It wouldn't be that small an arm if it has to use those chunky big threads. :lol:
Tim buddy, your right mate :lol:
Maybe they've reacher's disease? Small arms and deep pockets :lol:
Oh damn, that short arms :geek:
251 ENG
Post by 251 ENG »
The thread is 5/8" 16tpi WHIT form .
Use to work somewhere that had 100,s of taps that came from Morris engine,s when it shut down .
ianh1968
Post by ianh1968 »
Well, it looks like Whitworth won...
Thanks for all your suggestions.
Does anyone know where I can buy decent hex-headed crank pulley bolts of a sensible length?
Presently I have Allen screws, but I think that a proper hex with its larger contact area would be better.
Smiffy
Post by Smiffy »
ianh1968 wrote:Well, it looks like Whitworth won...
Use a verto one and cut it down, took about 3/8 inch of mine iirc
ianh1968
Post by ianh1968 »
Thanks, Smiffy...
Great idea to use a Verto bolt!
Do you know what the A/F size is? Is it metric? (I hope not...)
Smiffy
Post by Smiffy »
Yeah it's metric, 30mm
