There wasn't any on the bits that came off.
The shims are for if there is no/not enough endfloat, so you effectively increase the length of theLord Croker wrote: & to be able to set this up with shims is a lot easier than taking a few thou of the shoulder of the shaft.
I only machine the thrusts (if needed) as I make my own pins - fronts and rears - and they are properly hardened and ground to size, like the originals. All the pins available these days are soft and can be filed. Try that with an original pin. The thrusts are hard but softer then the pins and so machine easyianh1968 wrote:Machining the shaft shorter is what you do if you have the opposite problem, ie too much endfloat...Lord Croker wrote: & to be able to set this up with shims is a lot easier than taking a few thou of the shoulder of the shaft.
NB: Putting the shaft in a lathe and turning off a few thou is much easier than trying to machine a
recess in the thrust washers.
