Rockers on 8-port
Discuss all aspects of Classic Minis in Motorsport be it historic or current, the cars, the personalities & the venues
Astro
Rockers on 8-port
Post by Astro »
Hi
does anyone know what type of rockers have been used on the 8-port heads from Arden and Weslake in 1970? Have it been the forged Cooper S (1.22:1) ones, the latter pressed steel (1.27:1) ones to be used in the Cooper S mark III, or those still mentioned in my old Leyland folder to be available at that time, the AHT436 (1.5:1)? :?:
Astro
Re: Rockers on 8-port
Post by Astro »
No one?
graham.codling
Post by graham.codling »
on the weslake i use forged s standard rockers with no problems to date
Astro
Post by Astro »
Thanks! But this was not a technical question but a question about what FIA will allow. That means, what was used in 1970. I have no idea how to argue with this part.
Best regards.
sandman
Post by sandman »
Astro,
What date and number is on that S/T paper?
Cheers,
Ed_
Astro
Post by Astro »
Hi,
no date, just called FIA Form of recognition C-AKD 7955. Later on was written: A complete rocker shaft assembly fitted with special high lift rocker arms is available and will give a further improvement to performance. This part C-AHT 436 is advised only for full race engines.
big-un1967
Rockers on 8-port
Post by big-un1967 »
On the Weslake heads, they were Standard "S" ones, with spacers in between.
Not sure on the Arden
Hope that helps?
Astro
Post by Astro »
Thank you! Not really. :roll: The S ones mean 1.23:1, the pressed steel ones 1.27:1 and the C-AHT 436 ones 1.5:1. More is better, is more power. The homologation sheet says nothing. Therefore I am struggling how to explain the marshals if they will ever ask.
Dai Bos
Post by Dai Bos »
These are the pictures of my 8 port Arden car, which was once owned by Jim Whitehouse. The rockers are 12G1222ME forged rockers, they also used the press rockers which Jim Whitehouse welded the tops and bottoms. Its important to use the correct rocker shaft posts. There are a number of other rockers that could also be used but the best ones Jim found to be are the 12G1222ME's.
Dave Boswell
Dai Bos
Post by Dai Bos »
Here's the last pic of the 6 that I was meant to post.
Dave Boswell
Astro
Post by Astro »
A big thank you! :D
guru_1071
Post by guru_1071 »
we are just getting a set of the c-aht436 mechanical type rockers redone to suit the Arden head, the posts are different to the ones used on the five port.
Astro
Post by Astro »
guru_1071 wrote:we are just getting a set of the c-aht436 mechanical type rockers redone to suit the Arden head, the posts are different to the ones used on the five port.
any details (price, pictures) available?
