Reece fish carbs , all the old stories say they are great , work wonders etc , anyone in this era used one ?
I've tried 2 , (see vmaxscart on youtube) they always give very rich mixtures when set up according to the instructions . I have a rolling road with wideband gas sensor so its easy to see whether anything really works .
I tried adjusting them to give the correct mixture and have to say disagree with all of the old school assumptions in that it atomises the fuel better than an su , i fact looking down the carb when opening the throttle it just chucks about a tablespoon full (nice metric measurement ) down the barrel completely un atomised !.
I'm trying an amal concentric now which does seem to run better at idle at least to 1 perc co just waiting for some spare time to get it back on the rollers !
1963 850 super deluxe
reece fish carbs, amal, su
Re: reece fish carbs, amal, su
Stuart,
I tried a 1.5 inch Reece fish years ago on a moderately tuned 1071 & found very similar results to you.
It always seemed to lack adjustment. Right(ish) at tick over, meant lean at high revs & right at high revs meant spectacularly rich at tick over.
I suspect that Clive Trickey's advocacy of these carbs may have had more to do with money changing hands than actual performance improvements.
They seemed to work on Mini7 racing, being the carb of choice at one time. So maybe they work well at full throttle. i'll see if I can have a word with someone who used to work with them in the 60s.
knew someone who had a pair on a Mini Marcos for sprinting and he seemed to spend the whole day adjusting the carbs between runs.
- Frogeye61
I was under the assumption they were variable for the whole range, but that sounds too simple. And as a single carb they should work well, NEVER use a double. This much comes from the good book. And no I've never used one.
However in the old days they wanted a good rich mixture. Richer meant more power, but not too much. On the dyno we achieved best power at lambda 0.85, which means air fuel ratio around 12.5:1. If the fish could hold something around this - and it really didn't matter how close - it would work fantastic.
But it won't continuously hold lambda 1 (14.67 a/f) which is critical for catalysts. Therefore engine management systems for the newer cars.
Yep that seems to ring true , although i tried two carbs it was just to check I didn't have a bad one , haven't tried as twins . It can hold full throttle mixture at 12.5 afr good for racing although I still worry about the full 'dump' throttle enrichment . For road use I need control of idle , cruise and mid range . The Amal carb does seem to achieve most of this , it needs much lower fuel pressure at 1.5 psi and its a bit of a pain setting up with upper and lower jets , needle and air bleed screw .
Reinforces how good the old Su is !
It ran 55 bhp with twin 1 1/8 in su's
52 bhp with single 1 1/4 reece
The Amal is 34 mm no figures yet
10:1 comp , 12g202 modified head , 1960's small bore 3 into 1 with 1 1/2 exhaust (od)
I have just looked in Trickeys yellow book. He describes how to adjust the cruise air fuel mixture of a Fish carb by adjusting the radial position on the spindle of the throttle butterfly to prevent the mixture being too rich at part throttle
Yes I ran through many adjustments with the fish carb correct mixture at light load meant too rich at idle , moving the butterly disc is an art , moving it such small amounts i could not feel but saw Changes to the mixture on the rolling road .I did drill out the air bleed holes from 2 mm to 4 mm giving more bleed at tick over thus reducing airflow over the butterfly . This did make a better idle mixture but then too lean at light load .
Friday was spent on the rollers trying to get the amal to work , again like the fish 2 out of 3 was achievable idle/ cruise/ full load but not all three.
I was trying to find the best period car setup with this , what I didn't realise earlier is that the hs4 carb was manufactured from 1958 with pre wax stat jet , while I had been looking for a h4 to try .
Today I fitted the hs4 after rebuilding checking etc etc , really it's amazing . I have throttle response ,no flat spots 14 :1 at cruise , 12.4 at load and it's like a different engine , really had me thinking today how good it is for a 850 ! 58 bhp @ 5000 rpm and 45 ft lbs at 4000 , comparing to twin 1 1/8 at 55/33 respectively . Also hydrocarbons down to 350 at idle , twins 800, Amal 1300, Reece 2000!
Single su why did I ever doubt it
Single su why did I ever doubt it.
Couldn't agree more, but for most people the look is as (if not more) important than the performance
