2 vane steel?
4 vane steel?
6 vane steel (tropical)?
16 vane steel?
12 vane plastic 12A2129?
11 vane plastic 12G3105?
I especally want to hear from you Portugese/Spanish/S African/Chilean boys!
I guess that's why radiator muffs were inventedmk1 wrote:too much cooling is no good either...
You can't get "too much" cooling if a sensible thermostat is fitted. I usually fit a 76 or 78° one.
True. Somebody over here fitted a 74 degree theromostat in an 850 plus an extra fan! The guy couldn't really understand why his engine didn't run that well...mk1 wrote:too much cooling is no good either...
Hi there...YMJ wrote:I especally want to hear from you Portugese/Spanish/S African/Chilean boys!
LDR209H wrote:Is there an electric fan kit you can buy that fits inside the wheelarch which doesn't require butchering of the inner wing ?
Sounds good Rich,was it this one ?Richspec wrote:LDR209H wrote:Is there an electric fan kit you can buy that fits inside the wheelarch which doesn't require butchering of the inner wing ?
Define butchering, Minispares do a kit which my brother fitted after the original inner wing fan died on his 93 sprite and I just fitted a cheapo fan off ebay, all it needed was two holes drilling to hold it in place?
