HIF twin carbs on a S manifold
Jono
Post by Jono »
I have a pair of 1.5" HIF carbs and an AEG 537 'log' type manifold. They came with the car as a kit of parts minus linkages (which I intend to make up) but with new heat shields and other hardware. I am planning using these on a 'hot' circa 85/90 bhp 1275 based engine in a Mk1 Mini
Clearly this manifold would have run with older style SU's with external float bowls and my question is will the HIF's work with the older twin carb manifold?
Sure, they fit and bolt up but the old manifold sets them at a steeper angle than on the single HIF modern type Metro/Mini manifold.
The concern is whether the angle is such that the floats will stick.
Any views or experience appreciated.
Jon
