fundamental differences between a 998 Cooper engine/head
rolesyboy
Has thanked: 19 times
Been thanked: 9 times
Post by rolesyboy »
Hi Folks. Just bought my latest project (oops!) and it has a regular 998 engine. What are the fundamental differences between a 998 Cooper engine/head than a Wolseley 998? Especially interested to hear of any block differences. Cheers. Mark
Rolesyboy
251 ENG
Re: fundamental differences between a 998 Cooper engine/head
Post by 251 ENG »
Head , carbs , manifolds , pistons , cam are all different .
Some early cranks had different oil drillings
Blocks are identical
rolesyboy
Post by rolesyboy »
Brill, thanks. I have a feeling that the pistons were D topped? Is that right and if I don't have them can I buy them (or get them machined if not?) Cheers. Mark
Rolesyboy
Lord Croker
Post by Lord Croker »
You are correct in saying that the pistons were 'D' topped, the D shape was in the form of a raised area of the piston crown, although you could probably achieve that shape by machining a flat top piston, it would not give the correct compression ratio because the D area is above the height of a normal piston, something I found out to my cost when I once fitted an 850 head to a 998 Cooper, (in an emergency situation), there was contact between the pistons & the peaks of the combustion chambers. The sharp peaks do not exist on a 12G295 head.
