minispares steel cooper rims
Anyone bought or used the minispares steel cooper rims? It says advisable to use an innertube
which i thought was a bit strange?
- Pete
- Has thanked: 57 times
- Been thanked: 147 times
Re: minispares steel cooper rims
If you mean the MiniSport vented steel rims yes they have had issues. Dave (Mk1 rally) was using the 4 1/2's and had a total tyre deflation on an event earlier this year when he cornered hard, not ideal !
- Has thanked: 4 times
- Been thanked: 23 times
Could it be that they don't have the raised 'humps' in the rim that are meant to retain the beads on tubeless tyres? I've had trouble in the past with tyre fitters refusing to fit tubeless tyres to Mini rims because they were missing.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
"Proper" S rims don't have "J" ridges either.... The ridges came along long after the S rim and was invented to stop soft tyres deflating completely (when the tyre bead drops into the centre gutter).
Its possible to roll a tyre off the rim but it usually only happens with under-inflated tyres... I've autocrossed, motorkhanad and hill climbed on S rims and never lost a tyre.
Cheers, Ian
Cheers, Ian
- Been thanked: 10 times
I've used Minisport 'S' rims for 3 years now , and used them HARD , never had a problem withs tyres coming off.
