Hi all, thank you so much for the imput, and mini129 thanks for the offer, really appreciated! Hope I can get it run, or I'll definitely seek your help!
Ok, back the tacho, looking at it again I too guess it was a later gauge that got convert inside and on the face.
So, as Mark said, the single blade must be negative but still connect to the fuse(live feed???), although it is infact to the negative of the battery, as other equipments on this Positive earth car did??? Am I wrong?
But, one interesting thing as by mini129, when looking at the 2 different fitting instructions from Mark's site, the 1st one said the loop is connect to coil AND fuse block(as pointed out by 62countryman). But for the 2nd instruction, the loop is connect to coil AND dizzy(as point out by Mark). Killing me!!!
