clutch system leaking
ronie
Post by ronie »
I tried to bleed my clutch system today. It was going well until the connection of the metal pipe to the hose going to the slave cylinder started leaking.
The metal pipe is the original steel one (51 years old) , and the hose going to the slave cylinder is new.
Any tips or tricks to make this connection dry?
Lord Croker
Re: clutch system leaking
Post by Lord Croker »
I think a new copper pipe would bed into your new flexible hose end more easily than a steel one. If you are keen on keeping the old pipe for originality there is a sealer for such joints available from Frost Auto Restoration Techniques, http://www.frost.co.uk It's called brake & pipe sealer.
Ronnie
Has thanked: 13 times
Been thanked: 35 times
Post by Ronnie »
Check the flair for fractures and also that you have got the correct rubber pipe fitting (Concave or convex).
Canuk
Post by Canuk »
This happened to me when I replaced the flexible hose..It turned out the female end of the hose was longer than the old one, so the end of the metal male pipe could not seat properly.
I cut a piece off the end of the flexible pipe and all OK...
JC T ONE
Post by JC T ONE »
I once bought a new flexy hose, it had a scar, in the conic part, where the male pipe is suppose to seal (poor fabrication) .
I made a small cobber washer, put that into the hole, and all was fine 8-)
