Hi ,
Does anyone have a photo or drawing of the mod required to the rods to clear the cam on an 8 port please.
Is there any specific type of rod which can't be modified to clear the cam?
Rods for ARDEN 8 Port
Re: Rods for ARDEN 8 Port
Ask bmceccosse on the mini forum. He did it for someone 40+ years ago. see how good his memory is.
you can use the aeg625 that minispares sell - they have been modded from bare rods by arrows to use a bolt, rather than a stud and a nut.
old s rods 'may' sometimes need the top of the stud releiving, but this depends on cam choice, rod, stud etc
- pad4
unless you want to use original stuff i would suggest using H beam rods which miss the cam by a mile... specialit components ones are pretty reasonalbly priced.
Hi,
but SC can not deliver since half a year. If you have A+ pushrods and for example a SW23 8port cam, you can lower these two bolt seats where the bolt heads will contact the camshaft about 3 mm’s and not forget to cut the bolt of the second cylinder the same 3 mm’s. Otherwise it will contact the gear housing.
- Vegard
SC billet rodd. I'd rather use the forged originals. The Minispares ones Rich mention are infact very nice.
