steering rack
captain
steering rack
Post by captain »
hi all need a steering rack for my mk1 :?: somerford say :!: the mk1 rack is superseeded to the mk2 part number does this fit without any probs :?: thanks in advance
Chalkie
Re: steering rack
Post by Chalkie »
whats part number for a mark 1 steering rack? cause ill see if i have one :) I have 2 spare i got with laods mark 1/2 parts
66S
Re: steering rack
Post by 66S »
A Mk2 rack will fit a Mk1 but you need different tie-rod ends, they are longer ............. I'm pretty sure !!
( Edit) Hmmm, I stated tie rod ends, I was meaning to say steering arms !! I'm going nuts !! Thanks 1071S
Regards
1071 S
Re: steering rack
Post by 1071 S »
Well... no. But you do need new steering arms - well you don't REALLY need them, in that the car will drive OK without them. But I'm told the matching steering arms work better...something to do with Akkermann (sp??) angles. and the factory fitted them as a set.
The BIG deal is the 3 feet or so they (Mk II setup that is) chops off the turning circle diameter....
Well worth it IMHO.
Cheers, Ian
captain
Re: steering rack
Post by captain »
thanks for all your help folks,got the job sorted :!: thanks again
