It had a single HiF44 fitted before so the floats etc are different. The ones fitted were OK a few years back so I'm assuming they should run on this one. But I will check their angle.
It has the latter non adjustable floats, and they measure correctly so they're gapped OK.
But I'm looking at other items that the car needs so turning my attention to those first. Then, well I'll probably get it taken to someone to try and sort as its now beyond my abilities.
Basically, car drove into the garage
- Ran OK
Engine has only got 250 miles on it since its build
We swapped to twin SU's
Fuel is pumping into the bowls
We have a spark and we haven't touched the timing
The carbs have been adjusted for its initial start
Won't fire using easistart
No sign of an air leak
Plugs appear wet after trying
