Stroked engines
Stroked engines
Hello, can I measure the stroke of a crank by measuring how far the piston goes down the bore from tdc? I have a inline a series engine Im about to sell and I was told it was a 1430/1460 Can't remember which so I figured id double check it before I sell it.
Re: Stroked engines
Yes head is off, sorry I neglected to mention that! I have a long dial gauge and was just going to measure it with that!? In my head that makes sense!
Re: Stroked engines
That should do it, or a good steel rule. Measure the piston down the bore at tdc and the repeat with it at bdc or simply measure the next bore.
then it's bore dia x.5 x squared x pi x stroke x 4 = capacity
- Mini4Ever
Re: Stroked engines
Being used to mathematical formula on a daily basis:
Which means for an A-series engine (4 cylinders):
In both formula, the Greek letter is called pi, which is valued 3.1415...
Filling in the Bore and Stroke values in cm gives you the capacity in cc. This gives the numbers that we all know for the standard engine sizes 848cc, 970cc, 997cc, 998cc, 1071cc, 1098cc, 1275cc. These numbers are actually rounded as they are in reality closer to: 849.4cc, 970.5cc, 995.2cc, 998.4cc, 1070.1cc, 1097.2cc and 1274.9cc respectively (presuming that the bore & stroke values in my books are correct).
Too many cars...
- Been thanked: 6 times
Re: Stroked engines
You can measure it with a ruler
1430 is 73.5 bore and 84 stroke
1460 is 73.5 bore and 86 stroke
If it,s 1460 I have someone who would be very interested in it
Re: Stroked engines
Cheers chaps, i'l let you know 251eng
I use this equation 3.14 x (piston size) x (piston size) x stroke= cc
For example to get 1460cc
3.14 x 73.5 x 73.5 x 86= 1458823.6 = 1459 cc (1460)
- Has thanked: 4 times
- Been thanked: 23 times
Re: Stroked engines
Err, nup that formula doesn't work. By chance it gives you the right answer, but only for that size of piston.
It needs to be pi times the piston radius squared (you've used diameter) times the stroke, but that's only for 1 cylinder and you want it for 4
So
3.14 X 36.75 x 36.75 x 86 x 4 = 1458823.59
divide by 1000 to fix the units = 1459
With a bit more precision to pi it works out closer to 1460.
So
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
Re: Stroked engines
on 'another forum' i was recently amused to see a 'youth' claim that his engine was a '1355 innit' because it was plus 20.
his mathamatical reasoning was that you added the 4 x +20 to the original engine size, so 1275 + (4x20) = 1355....
god knows what he would do if it was stroked!
- Vegard
Re: Stroked engines
Excellentguru_1071 wrote:on 'another forum' i was recently amused to see a 'youth' claim that his engine was a '1355 innit' because it was plus 20.
god knows what he would do if it was stroked!![]()
Re: Stroked engines
Vegard wrote:Excellentguru_1071 wrote:on 'another forum' i was recently amused to see a 'youth' claim that his engine was a '1355 innit' because it was plus 20.
- Mini4Ever
Re: Stroked engines
As indicated in my post, the formula's are equivalent for a 4-cylinder engine. As you will agree Radius = 0.5 x Bore (to complete things Bore = Diameter ≈ Piston Size). Squaring the Radius is then equivalent to 0.5 x Bore x 0.5 x Bore = 0.25 x Bore x Bore. The 0.25 disappears against the 4 of the cylinder count.Tim wrote:Err, nup that formula doesn't work. By chance it gives you the right answer, but only for that size of piston.
Sorry, I'm just a nerd sometimes
Too many cars...
Re: Stroked engines
My apologies, you're correct. As a professional nerd I'm embarrassed that I'd never noticed that.
But just so that I can be more correct, your formula starts to get messy for anything with a different number of cylinders.
1955 BSA C11G
1969 Triumph TR6R
1955 BSA C11G
1969 Triumph TR6R
Re: Stroked engines
obviously using the squaring of the bore works exactly the same as the std formula on a mini engine. But it fails a bit on a 6 or 8 and is not really much use on a 28 cylinder radial aircraft engine.
- Been thanked: 10 times
Re: Stroked engines
I imagine it would certainly involve a hard on
- Vegard
Re: Stroked engines
What are you saying Mark, that it gets harder the more its stroked?mk1 wrote:god knows what he would do if it was stroked!![]()
Re: Stroked engines
Blimey maths was never my forte!
My education went as far as "the wheels on the bus went round and round" then i discovered minis......
I have a 13 year old son who would understand those workings I will get the lego out and get him to show me
Re: Stroked engines
How does my equation come to prety much the same answer though? Haha! granted if I got it wrong I got it wrong! But it's funny it pretty much works?!Tim wrote:Err, nup that formula doesn't work. By chance it gives you the right answer, but only for that size of piston.
So
Re: Stroked engines
Also, iv measured the stroke at 83.6 which I came to 1418cc.. thought it sounded odd to me!
what does that stroke give in cc with the correct equation?
I've provisionally sold the engine and told him what Cc I came too. So I would like to know for definite what it is!
