Snail Blower Air Inlet Valve
gs.davies
Has thanked: 63 times
Been thanked: 64 times
Post by gs.davies »
Does anyone have any detailed pics of the inlet valve for the snail blower type heater? Interested in how it attaches to the front panel, how the valve control is oriented and if it's a straight or angled tube. Is any kind of filtration fitted or does it just hoover up whatever detritus finds its way in?
I am wondering if one can be salvaged from a Midget heater box..
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Re: Snail Blower Air Inlet Valve
Post by woodypup59 »
I had one years ago. The inlet was probably 3 in diameter and screwed to the grille aperture. It had a mesh grille on the front . It must have had a flap valve in it because I remember the extra control knob in the cabin.
It might be shown in the right AKD parts manual.
360gts
Been thanked: 42 times
Post by 360gts »
gs.davies wrote: Wed Nov 20, 2024 11:29 am Does anyone have any detailed pics of the inlet valve for the snail blower type heater? Interested in how it attaches to the front panel, how the valve control is oriented and if it's a straight or angled tube. Is any kind of filtration fitted or does it just hoover up whatever detritus finds its way in?
It's possible...bit of work. The angle is wrong at the front where it attaches to the front panel.
You will need to reshape the front area.....this will shorten the tube. I have done it.....once in place...no one can tell the difference.
I cut the flange off....leave about 1/4" of the tube on the flange....this will help align the flange back onto the tube when you have made a new angle on the tube.
Braze/weld the flange back on....this is what it looks like when finished. Held on with two self tappers...and yes, it just sucks in whatever is in the way.
FYI, the seal for the flap valve is available from Somerford.
360gts
Post by 360gts »
double posted...apologies.
gs.davies
Post by gs.davies »
360gts wrote: Wed Nov 20, 2024 4:57 pm
Great stuff, I thought the angles looked a bit off on the Midget heater box. How does it eventually align on the Mini? Is it perpendicular to the inner wing and does it curve upwards to the blower inlet? Wondering how it also doesn't fill itself up with water driving in the rain..
360gts
Post by 360gts »
gs.davies wrote: Wed Nov 20, 2024 5:44 pm
The original tube does lay parallel to the wing and is very slightly pointing upwards.
After cutting and forming this MG tube (oops...almost called it a MIDGE🤣T) ...I got it fairly close to being parallel.....doesn't matter all that much.
Remember, the more angle you put on the front of the tube means the flange will be smaller than the angled opening...so, it is a compromise.
Hope this makes sense.
