ie.
The magic wand gear lever poked through a slot/hole in the carpet with the rubber gaiter and the metal retainer ring not visible screwed directly to the metal floor/tunnel UNDER the carpet.
The remote and later rod change gear levers had the carpet cut around the rubber gaiter shape also with the metal retainer ring and screws not visible and screwed directly to the floor tunnel UNDER the carpet.
Am I right or wrong? Is this perhaps starting to become similar to the upside down door card issue?!
Also back in the day when Minis were daily drivers you frequently had to remove the soaking wet carpets from the front of a Mini, especially in winter to stop the windows misting up inside and it would have been a pain to have to unscrew and refit the gear lever gaiter every time!
Incorrect
Factory correct
Incorrect
Circular carpet cut-out
Rectangular carpet cut-out (image from 1968 Mk2 Mini Brochure)
