wiring loom question
ronie
Post by ronie »
I am finishing the wiring of my 1961 mk1 Mini. I bought a brand new loom, but some of the colours of the cables do not match the wiring diagram, or I do not understand exactly where to connect.
Could you give me a hand?
I also bought some bulbs for the binnacle lights, but I cannot get them to sit in place. The bulb holder also look quite different, compared to the original loom.
What type of bulb should I get?
Thank you.
Re: wiring loom question
Perhaps this diagram will help
The bunch of black cables with the ring connector need to be grounded to earth.
As for the bulb I would ask the suppler of the loom.
111Robin
Been thanked: 18 times
Post by 111Robin »
The bulb is the screw in type. GLB987 from Minispares.
Jack of all trades
Post by Jack of all trades »
If the diagram is to difficult to read;
On the voltage regulator;
E has 1 black wire
D has 2 Brown/Yellow wires
F has 1 Brown/Green wire
A has 2 Brown wire
A1 has 2 Brown/Blue wires
The black grounding wire should be attached to the speedo housing (its the grounding for the lights in the speedo)
Jack
ronie
Post by ronie »
Thank you all.
Will attack the loom, with my new found knowledge.
