Before I do this I was planning to tighten the two output shafts to torque and fit the split pins. Last time around we used a kind of scaffold tube to stop the UJ turning - using the normal U clamps. Any better / easier ideas to lock it all up to tighten?
It has been around 30+ years since I last did this, so any last minute tips welcomed. FYI my timing gear and adaptor plate etc is still fitted so any tips on ensuring the half moon seal doesn't move are especially welcome - as I won't be able to see it will I?
BTW all paint has now been wiped very cleanly off any gasket areas - it was still wet when I took this pic
